Help with cabrio top latch!!!
(In Topic #201635)
where to buy, how to fit?
Can anyone let me know where i can get hold of a top latch for a cabriolet?
Just bought the car on Saturday and noticed the drivers side top latch has lost the safety catch
So if i go over any sort of minor bump, it can pop open the latch… not ideal and not easy to refit when driving!
Thanks in advance for any help!
First MK1 purchased 19th Dec 2015:
MK1 GLS 1.6 Cabriolet (1981, X)
How do i adjust the drivers side so it doesn't pop open then?
It seems stiff/taught at the moment when closing it, need to apply a fair amount of pressure to secure it. Will losing the 'J' hook slightly help?
On the drive
Myvalver 89 GTi Grey mk2 16v
Also you shouldn't need to apply a great deal of force to open or close them.
That's why you should have an adjusting ring nut on both sides above the hooks!
So your set up is how VW built the car.
Pics showing the issue helps, but it's common as the metal fractures with use over the years. Generally theres 3 threads showing above the lock ring on the J hook.
On the drive
On the drive
First mk1 and it's keeping me busy!! Haha
On the drive
RichieS said
does the silver hook part simply need screwing in a bit tighter? Once its in the correct place, tighten up the collar that goes around it to hold it in place - not exactly convertible weather right now is it
Yes does look a little too far out.. also the rust on the handle maybe be hiding a stress fracture.so double look in that area also. If you need handle I can sort you a drivers side 1.
On the drive
