Heating Matrix Blown!
(In Topic #203466)
Has anyone experienced this, have advice or a technical drawing for changing the heating matrix?
Thank you for any advice.
it is a bit fiddly, but not too bad.
2001 Zafira 1.8
2001 Zafira 1.8
Do leak, you said burning plastic which would tell me that the Motor is more suspect than the core.
A/C equipped cores remove differently, and non-a/c
But I would ask if the Radiator Expansion jug is low before I tried to do a heater core.
They make a pressure tester cap that you place on the expansion jug then pressurize it to like 14-18psi, and you will find a leak rather quickly without having to run your engine.
For a/c Equipped there is a how to that you can use but after wards you have a ugly seam where you cut it out.
I have the fix for that to make it more OEM. As in the A/C equipped you have to take the dash out to do it correctly.
http://www.driversfound.com/scirocco/techtips/body/heatercore/
My creative use of a old tool tray plastic and 3 trim screws to make the cut "invisible?"ok, slightly less obvious.
