Right guys I really need some help on this as I just can't seem to get to the issue, so my heater blower isn't working, I checked the resistor and That's ok for both resistance and continuity, the motor is working if 12v is put directly to it, now I found a burnt pin on pin 19 on the blue plug and this is the 12v wire for the blower I believe , now I renewed the plug and wire and cleaned the pin on the fuse box but the heater blower is still not working any ideas what else to check or could the pin inside the fuse box have melted out as around the pin is seems melted, also is there any way to check this and resolve it, just pulling me hair out with this one, or could i bypass ir somehow and see if it works without going to the pin in the fuse box , all help is appreciated in advance thanks
Sent from my SM-J510FN using Tapatalk
