Heater motor removal
(In Topic #241423)
I've got it out of the heater box in the bulkhead but can't get it out of the bulkhead area. I've removed the
Ignition module under the n/s but it won't pass out through there.
I've not removed the wiper mechanism so whether it comes out that side of the car ?
Please don't tell I have to remove full heater box etc from under dash
Website Manager
You could try lubing the shaft a little and see if that free up the motor and then you dont have to remove anyway?
You will need to disconnect all the wires as they go inside the car.
Don’t forget to replace the foam around the motor where it touches the heater box, you don’t want any water leaks into the car or extra noise from the fan running.
I've tested direct from the battery and it (bearing) gets very hot on the motor so for safety sake - they are only £37 new.
I'll have a go at removing it from the wiper side - I was really hoping that would be the case 🙏
It's certainly one thing after another with this rebuild- it's been 8 years to the day I acquired it.
My new Febi fan moves more air than the old one which stopped working on speed 1.
The a/c motors are a pain in the pocket book to replace and getting hard to find over here.
Fairly easy to remove. The only real Pain in the Posterior is finding the screws and nut on the cabin side. Then knowing how to get the little nuts held in place to screw them back. (Big hint) a latex glove and a drop of super glue so you can position it with your finger.
Hopefully I'll have a fan working (safely) then.
Bit of a mare replacing the motor as I'm finding out.
Good luck
