Header tank not secured
(In Topic #233565)
Hi all, I have a 1991 GTI cabriolet and was wondering why the header tank on it is not properly secured and stay as it should. It is held by couple of tie wraps to hold it in place but still is at a tilt. Could it be that it is the wrong one. Will put a picture up in a bit and any help is greatly appreciated.
Looks like the correct one as far as i can tell, if its not damaged perhaps a bit of gentle manipulating of the metal mounting bracket…
Am I best taking the tie wrap off and then seeing if the brackets are bent or put picture up for info / advise
Sent from my AC2003 using Tapatalk
Yeah , lift header tank out the way, and as said if the tank itself dosnt look damaged / worn bend the brackets untill the desired fit is achieved…
Ok thanks will try that should the brackets have a rubber seal on the ends to make it sit properly
no
Ok thanks very much for all ur help abfmk1 much appreciated
