GTI Mk1 Wont Turn Over or Crank!?
(In Topic #215873)
Thanks in advance.
Is it a convertible? If not then it's a mk2.
Whatever check your battery terminals and earth to start with.
How old is the battery?
Because it draws a great deal of power to turn over the engine.
Often you'll find that it's got enough to power lights and stuff but that's nothing compared to the drain on it when it starts the engine.
Just take your time and be methodical about how you approach this or any other issue.
I often say to people when I see them getting totally carried away with a problem to stop and I use this as an example.
I say look if my car doesn't start I look to see if there's any petrol in the tank first. I don't start by jacking it up and ripping the back axle out! 😉 👍🏼
Sent from my Smartphone ☃️
Does the car have an immobiliser, these can sometimes play up and disable the starting circuit.
Years ago I had a wonky ignition switch (the switch below the ignition lock) which give symptoms of a duff battery or starter. Try jiggling the key around.
Might be useful to join the AA or RAC………
Turn the ignition on to run.
Parking Brake on.
Take a large jumper wire and hit the solenoid wire on the starter to see if the starter will spin. If it does then look at a break from the ignition switch, ignition switch itself…
You can in stall a heat soak relay…see the below drawing.
Off loads current off the ignition switch shortens the wire run from the ignition switch to the starter solenoid by 5 to 8 feet.
If it doesn't spin, then smack it with a hammer 3 times, then try it again…..
if it starts after the smacking then it is the starter, if it still doesn't start it is the starter.
Going back install a heat soak relay, you 'll be glad you did.
Caveats:
Battery fully charged,
Ground wires from battery to engine are clean and no voltage drop.
Last edit: by Briano1234
Briano1234 said
Place the car in Neutral, or Park.
Thanks Brian. Tried all that. Still nothing. Doesn't start after hitting it or shorting it. So I guess im left to replace the solenoid starter?
I would suspect that your Solenoid is bad.
and that your starter itself is toast as the bearings or rotor was sticking….
Replace the starter/solenoid, and I would install a new bushing.
