Gravity Valve bracket
(In Topic #216112)
Photo of gravity valve bracket
I've spoke to someone recently about remaking the metal plates as they always seemed to rust out, if you want one I'll put you in touch with him when they're made up.
This picture any use?
https://www.ebay.co.uk/itm/VW-GOLF-JETTA-CADDY-MK1-CABRIO-SCIROCCO-MK2-FUEL-FILLER-TANK-GRAVITY-VALVE-2/391930504364?epid=1071761846&hash=item5b40e0e4ac:g:HGQAAOSwywRaEvR-
http://www.oemepc.com/
It may get you ideas of where it is mounted, and or what it might look like.
I have actually exact the same problem, also 20 years have passed ;-)
Did you in the meantime found pictures that you could share ?
Do you guys reinstall the mud guard?
Not all lines are covered and protected. This seems to me so small and insufficient?
Hence all the rusty filler neck's out there …
I was thinking of making some sort of rubber that could be stretched over all the lines to protect them from water, rocks and sand …
But there are probably already better ideas out there?
thanks!
I believe you asked Mars Red LA2A?
Mars Red it is !
Mars Red it is !
Re:
Hmm, should be a good solution to!sporttrucker said
I fitted a front passenger side arch liner in the rear arch before, fits very well with a little trimming.
And as Briano says, a good wash from time to time should prevent a lot of misery too.
As i recall there was indeed a ton of sand, salt and other dirt in there when disassembling the car …
Verstuurd vanaf mijn SM-G935F met Tapatalk
Mars Red it is !
Mars Red it is !
As its all out of sight I simply bent a metal strip to replace the original L bracket that had turned to rust dust
