Golf Alloy Wheel Size
(In Topic #221754)
Written in plain speak.
J = the profile of rim were the tyre sits
Ignore the J it just over complicates things
Most 15 inch wheels will be between 7 and 8 inches wide.
You will want an offset of ET25 minimum to ET42 maximum on 7" rims, go any wider and it becomes a more exact science
Its more likely the tyres will touch the suspension rather than the wheels themselves.
Anything other than standard ride height will need 195/45 tyres
Current rides:
All you never wanted to know!
Ian
Back spacing of the wheel becomes an issue if you have big brake set up and coilovers usually sit with the adjustment ring exactly where the tyre needs to be. Therefore a different tyre and wheel package is required for coilovers vs lowering springs.
Ian
