Gear Selector oil Seal
(In Topic #223522)
I've got a gear oil leak from the gear selector boot which looks like the attached pic.
I'm told I need a new seal. Can someone tell me what that seal looks like, what it's called and where to get it?
Also is it a gearbox out job?
My car is a 1.8 Clipper 5sp manual
Will the gearbox have to be removed to fit this.
I'd try with it in postion 1st, dont think there is that much in the way on a carb clipper compared to all the K-Jet gubbins in a GTI. Obviously not as easy peering into the engine bay at awkard angles compared to having box on a bench but must be worth a try. Are you sure its that seal and not the speedo drive that leaking?? Or the drive shaft seal slinging oil about?zod said
Cheers Paceman, much appreciated.
This is the issue, I'm not sure which is leaking. It could be this seal plus the drive shafts as well.
But I'll try this seal first if I can do myself (without removing the box).
If not I'll have to call my mechanic.
And Kudos by the way for knowing off the bat that a clipper is carbed
zod said
Thanks,
Not that much kudos, just that I have a GTI (hatch) and Clipper Cabrio…. Might be worth cleaning up everything, topping up the box and seeing if you can spot where its coming from?
