Gear problem
(In Topic #225710)
Hi just bought a cabrio 88 gti 1800cc.
Ok wish I had not bought it but now to late. First off all when tying to hit first, it would always go in reverse. The gear stick is all over the place. Like the thing has moved to the left. Now I can not get reverse and first. What need repairing and how please. Is it easy and cheap. Or should I put a match to it. Lol.
Also it is always running hot 3/4 on gauge and fan running.
Last edit: by supeone1973
Bushes or linkage would be my first thoughts on gearbox issues - cheap enough to fix if that the case.
The temp gauge will be a process of elimination. Does the fan start running the moment you turn car on? That would suggest it's been wired directly due to "issues". Does the temp gauge climb rapidly or go up at a normal pace? Really need more info to offer ideas. At least the fan is on so it could be worse!
Old cars need looking after and you'll always be finding stuff to fix.
https://www.ebay.co.uk/itm/Gear-Bush-Repair-Kit-With-Rods-5-Speed-VW-Golf-Mk1-Hatchback-Cabriolet/312674923272?epid=1638183638&hash=item48cce0b308:g:OGAAAOSw6-Nbrgqt
The gauge should be @1/2 to 3/4 during normal running and in my experience the fan only runs if stood ideling for long period or doing a 3 point turn on a hot day etc
is this one better has a metal dish thingy
https://www.ebay.co.uk/itm/Comprehensive-Gear-Shift-Repair-Kit-5-Speed-For-VW-GOLF-MK1-CAB-SCIROCCO-JETTA/392852404789?fits=Model%3AGolf&epid=1978006409&hash=item5b77d3fa35:g:GhsAAOSwZ~pePdd8
supeone1973 said
Thank you for info and link. The gauge goes up really quick.With in. A few minutes of driving.
That doesn't sound especially quick especially with the weather we are having. Does it go straight to 3/4 and fan come on or does it only do that when sitting in traffic? Mine sits around half way when driving and there is air flow to cool engine but will go up when sitting in traffic before fan kicks in
Does it go down whilst you are moving in the road or stationary at a traffic light…or in Stop-n-Go…?
The direct above is to be considered normal.
Flushing and back flushing is a good thing to do every 3-4 years.
supeone1973 said
Yes ok thanks i think I will drain it.Any in sight on link kits above
I've not had to do the bushes etc before so just using a bit of logic, the metal bracket will just replace the one that is already there if needed.
But it has 6 solid reviews with people saying quality is spot on so I'd go for it based on that. So my vote is for one you posted with the metal bracket
