Gear linkage problems with reverse
(In Topic #207041)
Hi all, Looked at a few old posts don't know if my clutch set up is correct I seem to get allot of movement in the cable and I have had to fix it using cable ties into position I saw on another post someone had done similar, why is this guys surely we shouldn't have to resort to this. Any help would be soooo appreciated please.
Last edit: by Lath1976
On my later cabriolet I have a plastic clip fitted to the brake master cylinder which holds the cable in place, thick wire works for me.
did you remember the 2 plastic bushes in the bottom of the gearstick under the car to the main link rod into the engien bay?
Okay I did replace the bushes in side the gear lever, I think from a bit of investigating the clutch wasn't fixed into position and it kept moving from its central position.
I am going to use wire to hold it into place and sort out the nut being at the top and making sure I have 10mm clearance.
thanks again guys let see what happens.
