Gear linkage assembly
(In Topic #233811)
I suspect im being dumb but for the life of me cant get them fitted - specifically item 38.
Both parts fit inside the car (unless this is where im going wrong) and screw into captive nuts on the underside of the shell. I just cant see how item 38 fits on top of item 46 and still fit through the hole in the shell??!
I did retro fit one to my Mk1 Scirocco as it did not come with one, I think the fixings are already there as it did not fit from above..
I'll see if I've any pictures…
They do appear on eBay every now and then.
https://www.ebay.co.uk/itm/VW-Golf-Mk1-GTi-shift-lever-Heat-Shield-Cover-plate-/255075381785?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338268676&toolid=10044&customid=EAIaIQobChMIrZLppu788gIVgxoGAB3iaALxEAQYAiABEgLpZ_D_BwE
I paid less than the 1 above in the link, another one may or may not appear again… A new rubber boot is readily available for the same price as the shield above so you could just replace the boot?… https://www.ebay.co.uk/itm/391807403656?chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=391807403656&targetid=1280441980681&device=c&mktype=pla&googleloc=9045664&poi=&campaignid=12126078219&mkgroupid=120032726582&rlsatarget=pla-1280441980681&abcId=9300480&merchantid=9954874&gclid=EAIaIQobChMIvs2e3O788gIVnhoGAB2cbgBHEAQYAiABEgLOmvD_BwE
Guess they corrode very easily and either fall off or removed as they are quite thin - mine had the odd peppered area which I treated and then painted with heat resistant silver paint.
I'll ask my body shop how much it would be to make one their own and decide whether I install it or not. Running an 1.8 16v but never had an issue before.
Sorry for breaking into your topic Baggins 😇
mark1gls said
I think 38 (the exhaust heat shield) fits to the underside of the car?
Thanks for confirming - the diagram is a bit misleading in that case! When i tried offering it up underneath the captive nut appeared to be in the way, ill try again.
adolf said
I have a picture - I've done mine in last year and didn't experience any issues from memory
Thanks mate!
ReinoutMK1 said
Thanks for the URLs Mark.
I made my own - it's somewhere in my build thread, had to make some modifications to it once I had the exhaust in place though. It was easy enough for me - I'm no fabricator!
