Fuel return line connection to tank
(In Topic #217320)
as per title, I'm looking for some good photos to show the arrangement of the fuel lines on a Mk1 GTi tintop. I have new Crazyquiff flexi lines to fit, and have gone back to original fuel pump/bracket/foam etc which was previously removed. I know where everything goes alright, just want to confirm the routing of the hoses and pipes in the area as it is quite tight for space around the fuel pump. The return line in particular just has a straight piece of cunifer pipe coming off the flexi, whereas the parts diagram shows this as having a 90° bend which joins to a straight section of 185mm long hose to connect to tank.
Cheers in advance.
Peter
