Fuel pipe needed
(In Topic #227925)
Fuel leaking
Hi all, I have a 1.8 GTI cabriolet 1991, which has started leaking near the drivers side rear wheel. There is a small rubber hose which has got a split in it. Have been reading that this is being caused due to the new fuel specifications and pipes get eaten through. I wanted to know that what are club members using for their golf which are suitable to use. Any links attached would be greatly appreciated. This is like the 3rd time in 2 yrs and want to get it sorted once and for all. Thanks in advance.
Regional Host NE
there are a few pipes in that area
could you narrow it down a bit
maybe an an image attachment
Fuel pipe needed
Hi yes sorry, it's part no 21.
Sent from my SM-G955F using Tapatalk
Regional Host NE
not sure if it is 8mm to 10mm or 10mm to 12mm is that the one you are after
Fuel pipe needed
Hi yes that's the 1, it's a short pipe about 2 -3 inch length.
Regional Host NE
tipping it down hopefully it will stop sure i have
one lying about mate
Fuel pipe needed
If you do have 1 how much are you asking for it?
Regional Host NE
will see if i have one and get back to you
Fuel pipe needed
Ok no probs thanks
Hi nicci21paul, did you manage to have a look for the pipe?
Regional Host NE
will have a look just having issues with the golf and
the dividing fence to the neighbours garden gone west
Regional Host NE
will have one just busy digging out holes for the posts
Regional Host NE
pipe cut in half mate
Fuel pipe needed
No probs thanks anyway
Dont mean to be rude… but WTH put another old bit of fuel line on? also keep away from ebay fuel lines… get proper traceable fuel lines from reputable out let..
Rubber Fuel Hose.
Ask nicci21paul to measure the OD and ID of the cut hose, then order a section.
Rubber Fuel Hose.
On the drive
Myvalver 89 GTi Grey mk2 16v
Fuel pipe needed
Hi Kenneth, its I think 12mm and 9 mm on the other side, if I was to put a 12mm pipe on both ends ethanol proof, and proper use fuel clips would this be ok. As I don't want fuel leaking due to wrong diameter pipe used on the smaller pipe.
You can buy a new hose here or vw heritage, it's not worth the risk with 2nd hand fuel hose when it comes to petrol.
https://vwgolf1.com/index.php/product/fuel-hose-reduction-pipe-11-to-9-mm-533201543/
https://www.heritagepartscentre.com/uk/533201543-fuel-pump-connector-hose.html
I believe the hose goes from 11mm down to 9mm so off the shelf fuel 1 size fuel hose will not work.
Pretty sure 10mm will fit.. most hoses have a bit of give ..when warmed up in boiling water. so would stretch to 12mm ,and definite close on 9mm But if the hose mark has identified from vwheritage is correct then its your choice.
As regards to rubbers and o rings they all have shelf lifes, and pretty much everything oem on golf mk3 is past use by date…so mk1 its even more so. At the unit ( Kennysclassiccars.co.uk) ive found 2 boxes of o rings all are unused but brittle..and unusable, these are rubber and nitrile.. and under 10yrs old.. which is why I say make sure hose comes from reputable retailers.
On the drive
Hi all, thanks for all the info regarding this issue have got 1 ordered.
