Fuel accumulater required for 1.8T conversion
(In Topic #221262)
Also can anyone also let me know if I can bin the brake regulator that sits at the back above the rear beam, I have the original 2 small valves that come off the MC that go to each rear drum. Please let me know.
Cheers guys.
With regards to the valves fitted near the MC, I think they are different to the cab ones. Can't find a new pressure regulator that fits at the back, however the new pre made brake lines I got from crazy quiffs are made to original spec, so I can either just join the pipes at the point where they would normally go to the regulator at the back or fit in pressure reg valves in place of the original valve, that way I can keep the pipes I have already. If I do this I would need to know what valves I could put in place of the original valve at the back.
Anyone know if the is an adjustable valve that allows 2 inputs and 2 outputs?
Thanks again
