Front brakes from golfmk3 GTI to golfmk1 cab
(In Topic #218181)
Brakes
Hello
Does Somebody knows something about those brakes from golf mk3 it fit in the mk1 cab. Golfmk3 has 5 wheelshols, is it possible to use calibers and ceeriers and by some golfmk2 256mm discs and mount on golfmk1.
Somebody
I could be wrong but I don't think that combination will work.
Why not. I found a adapters for the careers.
I think you can only use calipers from mk3 golf if they are 280mm discs, not 288mm. Also I think to use mk 2 golf 256 mm discs on mk1 you need to use hard to find caliper carriers, I think these are possibly from a 16v scirrocco (first one)
Some mk3 golfs had 4x100 wheels and VW11 brake calipers.
These spec calipers and carriers will work with no issues.
Girling 54 type calipers will work if you have the correct carrier brackets.
sounds like you've found some so buy them and try it.
Ian
Ian
