Flashing oil light all the time
(In Topic #229029)
I have a 1983 mk1 golf gti with a later cab engine fitted, I do not drive the car much only about maybe once a month to keep things alive.
I notice on start up my oil light on the dash would flicker very faint on start up and then once revved a few time it would go out.
Now when I start it the oil light flashes all the time, I have changed to sensor on the side of the block but still doing it, I am not very good with electrical issues!
Have also noticed there is only one wire coming from the sender unit which is brown and a stray wire not doing anything which I am thinking is not right?
The car fires up lovely and revs fine, cannot hear any bad noises and have checked the oil level which seems fine.
Any advice would be greatly received as its tad disconcerning driving down the road with the light flashing all the time.
Regards lockstar (Andy)
Mars red campaign
I have not yet replaced the other sender unit lower down but that will be my next move.
Thanks for getting back to me, do you think it could be a faulty fuel pump?
Mars red campaign
Sorry but I'm a bit of a novice when it comes to car electrics, (ask me to drill open a grade 4 Safe and I'm fine) but electrics is not my best subject!!
Mars red campaign
Mars red campaign
Any other thoughts?
Mars red campaign
It is weird it was flashing all the time now it's faintly on and off, I did go for a small drive.
Mars red campaign
I checked everything, senders, wiring all the way to the speedo etc. I ended up taking the speedo out of the car and I removed the 'L' shaped board that's behind the speedometer. I was sure it had to be a dry solder joint but couldn't see which one so I re-soldered every solder joint on the board. This fixed it though and it hasn't come back on since.
Thanks for all your advice Steve, I'll let you know the outcome.
Mars red campaign
Over here we call them a cold solder joint. That is were the solder after application gets hot enough to desolder from the connection but the connection isn't hot enough to flow and cools making it iffy. This occurs more frequently since they have changed the make up from the solder from 60/40 tin/lead to 60/40 Tin/Zinc…. If you also don't remove the old solder and re-tin or flux clean the connection you may have a future intermittent….. Going though this exact same scenario with a Gent fro Chicago that modified his WESTY GTI to a later Cabriolet style dash, well at least his cars previous owners attempt….
Also on these guy's they do not like Generic Filters, or lower than 10W40 or what I use in my Cabriolets 20W50….
Generic filters, store Branded Filters, Bosch, and Fram all have been known to cause an intermittent blinky oil light from hades…
What I have personally used with no issues are:
STP
Mobile1
Wix
Napagold
PureolatorGold
Mann
Mahl
GenuineVW….
I also add a bit of Zinc to the oil as they tend not to blend it with that itty bit..and can cause cam lobe wear
Add some zinc??
Mars red campaign
https://www.hemmings.com/stories/2012/10/18/tech-101-zinc-in-oil-and-its-effects-on-older-engines
https://www.hyperlube.com/blog/engine/the-effects-of-zinc-oil-additives-on-older-engines/
Mars red campaign
