Fitting wheel arch trims
(In Topic #235674)
I will be shortly fitting the wheel arch trims to my GTi. Any top tips? Is it best to start at one end of the arch, or the middle?
I have a wing that has never seen them fitted so will need to drill holes, how do you go about protecting from rust? I know I can put paint on the hole, but the self tapper will cut through that.
All suggestions welcome!
J
I didn’t self tap but uses a rivet gun as the screws rust in solid over time (or at least the ones I removed were).
With rivets they are easy to drill out and replace with new rivets.
Must admit I used stainless steel rivets just because I happen to have them, which means future removal won’t be as easy as aluminium.
If I had really thought about it I would have got black ones to look better.
Don’t forget a washer, the plastic is soft and it needs some support. Again get black or pain before using.
Ps I assume this is Tin top gti arches and not the cabby arch kit.
Yes it's a tin top.
Never thought about rivets, good shout that. I have got some plastic washers but I don't think they are black, another good call. EBay here we come!
Aluminium rivets should also work well as they should corrode instead of the steel of the wings.
I also used one of those plastic welding irons from amazon to fix side skirt mounting holes (they were ripped out) and also fixed a front end bumper with a big old hole where the plastic had been pealed back. you have to cut out little notches so the new plastic can take a good grip but its fairly easy to repair plastic with those little irons and filler plastic.
