Fitting dust shield to front hub
(In Topic #223842)
Has anyone fitted the dust shields to the front hubs with out dismantle the hub ?
Guess the only way to fit them without cracking the hub nut and dismantle t is to cut away a section so it slides over/around the hub
If you manage to get the old bolts out then yes the only way to fit it without taking the hub off is cut a section out and slide it on, just make sure you put it on the right way round so it curves away from the disc.
Found this post…
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Frunning-gear_2%2Freplacing-the-brake
FYI… if they are missing it’s not a MOT fail.
Found this post…
Brilliant - many thanks
Just what I was hoping was possible 👍👍😊
