Fitting dust shield to front hub
Has anyone fitted the dust shields to the front hubs with out dismantle the hub ?
Guess the only way to fit them without cracking the hub nut and dismantle t is to cut away a section so it slides over/around  the hub DB492AC3-3DCB-43CD-B18A-CE15F60B1B57.jpeg
MK1 Golf GTi Campaign:Alpine White, Vauxhall Omega MV6, Alpina B10 3.3 Touring, Dolomite Sprint, MG ZT V6, Volvo T5 R estate  6C2B5B6F-1CA5-44CA-A93C-6B7F5206CD7F.jpeg
If you manage to get the old bolts out then yes the only way to fit it without taking the hub off is cut a section out and slide it on, just make sure you put it on the right way round so it curves away from the disc.
Found this post…
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Frunning-gear_2%2Freplacing-the-brake
FYI… if they are missing it’s not a MOT fail. :thumbs:
Brilliant - many thanks
Just what I was hoping was possible 👍👍😊
