Finding the correct leads, dizzy cap and rotor?
(In Topic #209975)
confused
However trying to find the right parts has frustrated me since the Cabby was first registered in Feb 1985 with engine code FH104061. Which doesn't seem to help me when looking for parts distinguished by DX part numbers pre '84 and post '85?
Any help would be appreciated
Max
'85 MK1 Golf Cabriolet GTI
I recon you have the pin type cap (also know as sawn tooth) pull a hit lead off the cap and see what there.
I'll try and find a picture and post it up later tonight.
Ne Plugs come with the Tip on, they will not allow the High tension lead to engage.
You have to hold them with a plier and unscrew the tip.
Later type with sworn tooth/pin ht leads.
HT lead ends are like this for later type.
I always use Bosch stuff and code for the ht lead kit I use on my DX engine 1988 golf.
http://www.vwspares.co.uk/g1electrical.php
I have bought all Beru parts from AVS and installed them, (after i returned the wrong leads i had bought from VW Heritage, doh) and the car runs better!
But it still has the same hesitation issue, so going to look at timing because i'm sure its not optimal.
Again, thanks for the help
