Engine Fuel Pump not sucking fuel from tank
(In Topic #221172)
On the drive
Myvalver 89 GTi Grey mk2 16v
The 1.5 could be a mechanical pump on a Carbed car, but not on a CIS.
84.5 and up Cabby's have the dual pumps and larger tanks over here.
I would be thinking that he has a filter or tank issue as in bad swirl pit restricted screen in the tank totally rusticated tank or filler neck that is allowing fine particulates to clog stuff up.
Tank inspection is warranted, as he should be mindful of having way less than 3/4 of a tank before popping of the cover, better to have 1/2 or less.
The 83 should still be a bottom feeder off the tank instead of the top. As the top would be the fuel sending unit only on a 83.
Last edit: by Kenneth Cartwright
On the drive
Are you 100% sure the tank/pipes are not blocked? A common MK1 issue. Can you draw fuel up to the pump? (petrol tastes fab lol)
I too would ask that if you manually tried to pull fuel out of the Tank by cycling the pump by hand.
I forgot that years ago on a Truck I had I got the new fuel pump that I had the push arm on the wrong side of the shaft and it wouldn't pump at all. I took it off, and replaced it and I will be darned if it didn't start working.
If you have a Mighty-Vac you might try sucking fuel out of the feed pipe as that will answer you very quickly….You do have a Liter or 4 of fuel in the tank?
Just saying….
Regional Host NE
to pump more
Regional Host NE
it wrong like most of my posts
