Earth points ?
(In Topic #215567)
The earth crown near the fuse box takes all the earths from the switches and dash and a few things from the engine bay electrics too.
Good luck!
Ian
Earth points ?
Sent from my SM-J510FN using Tapatalk
I think you may have a couple of faults that are not interconnected maybe.
Right then, erm.
Rear lights issues - check the bulbs and the metal sections of the lights for corrosion. The lights like to leak and water causes the bulb connections to corrode and the the metal sections of the plastic bulb housing to corrode as well. Doesn't take much to stop the bulbs from lighting. I'm assuming running lights rather than brake lights or indicators?
Is the earth bar nice and clean? Are the earth points looking good or all corroded? Make sure all the wires are well connected and haven't been tugged on and loosened.
For the VDO's - Can you tell if the wiring loom is original or home made? Check the bulb connections as again they corrode in the gauges.
Check to ensure that the 12v source for the gauges IS as 12v source. One of the power out tabs on the back of the fuse box is only about 5v. If this one has been used they never work correctly.
How do the earth crowns look? Nice and clean or all corroded? Any other issues going on?
Ian
I always ask the 'silly questions' as I'm constantly amazed at what people presume other people know.
Anyway…….
Put the multimeter to the 20v setting. Probably over towards about 2 o'clock on the dial.
Black probe goes onto a good earth somewhere. Try the crown to start with, if it's not doing much try the door check strap.
Red goes to what you want to check the voltage of.
In this case the input wire to the guage, it's probably red. With the car not running you should have around 12v or so. If you're way below this then you'll have to check on the back of the fuse box.
Unfortunately this means either being a contortionist or lying on you back with your head under the dash whilst trying to hold two probes onto things. It's fun
On the end of the fuse box nearest the earth crowns will be some bare terminals. These are the auxiliary feeds. 2 or 3 are at 12v and for some reason there's one at 4v or so. I have no idea why! Some are permanent (always on) and some only come on with the ignition (when the lights are on, on the dash) you need an ignition 12v feed for the VDO's.
BTW, cabby or tintop? Engine size? Carb or GTI? They're all a bit different.
If the voltmeters working then, in theory, you have a good 12v supply and good earth for the VDO's.
If it's the oil pressure guage then it's probably the sender.
Hope that helps a bit
Ian
Earth points ?
Earth points ?
If so then one of the spades at the top and to the right in the picture should be empty.
I have found a pickup for a fuel pump on one these, but for the life of me I can't remember which spade I used. You could always tap into the fuel pump feed should you so desire.
If you do go down the splicing in route for a feed (if there are no spare spades) then carefully strip off some sheath from the wire and wrap your new wire around the core of it, solder it into position then cover with loom tape or electrical tape. Saves cutting the original loom up.
Alternatively pull a feed (in the same way) from the cigarette lighter feed.
Ian
Earth points ?
G spade 3 or 7 will do for an ignition feed, neither are fused. 3 is usually empty and 7 used by the rear wiper relay so will have to make/use a piggy back connector if you have a rear wiper
Earth points ?
the crowns have an earth to them from the main battery earth wire in the headlight loom, they are not designed to earth to the chassis though they probably will do as its decent metal on metal contact
Earth points ?
Earth points ?
The G spade 3 or 7 would be for the power side, but if they worked before they already had a power feed. possibly the fuse has popped for it, or a dirty connection somewhere.
If the wiring is OEM they are fed from fuse 11, which also does the indicators so thats worth a look. The wire piggy backs off the ignition live to the horn relay above the fusebox
Earth points ?
Earth points ?
