Door handle
(In Topic #229874)
Moving
Hi my passenger door handle will not open door from outside. You have to open from inside. My first thought is someone has put wrong door handle from golf and not cabrio as slightly different from reading on here. Do you think before I take skin off and find every point is broken in door card that it's that. When opening door the handle moves away from car this not opening door. Or is it just a screw
Looks like the screw for the door handle is missing, if you look on the side of the door there should be a Phillips head screw to hold the handle on
Unfortunately not you got my hopes up lol
It must be missing the screw or the handle is broken
i will take a pic of my handle tomorrow and send it you
The screw that holds the handle at the rear is here:
The screw at the front is under the center strip.
Pry it off carefully.
The bit for screw has broken. Time for the metal expoxy until I get one from Ali
€ 8,35 14%OFF | WOLFIGO Car Door Handles Lock W/ Keys Outside Exterior Front Rear Left Right For VW Golf MK1 MK2 Jetaa MK2 191837205A,191837206A
https://a.aliexpress.com/_BT9K9T
Epoxy will last about a day…. I have tried all types of glues over the years, and a new handle is the best fix. Just be sure you change your pawl and lock over from old to new.
Not even a day. I have order two from AliExpress. For 12 Inc postage. Mixed reviews I will let you know result when finally turn up.
€ 4,80 39%OFF | Front Left&Right Exterior Door Handle And 2 Keys For VW Golf MK1 MK2
https://a.aliexpress.com/_B1KN5t
Regional Host NE
looks like you have bought tin top handles
by the link
by the link
Damn it
No nothing wrong with them fit straight on i just need to change the barrel now.. today
Ok the lock barrel is not the same size. So you can not put old barrel in . Maybe you could drill out. Not to bothered as side door. Now all the pins have fallen out of new lock. So I have a 3d Jigsaw to do.
Change your pawl as said above otherwise does not lock!
Last edit: by supeone1973
Hi I think that file been closed.
www.cabby-info.com
Choose Exterior
To the upper left are 3 bars in a square.
DIY Guides
Replacing Lock Cylinders opens a PDF that you need to view.
It shows the original link at VWvortec but since they changed format all the old links are dead. IE: My how-tos that were on page 3 of the faq's is now page 4, it is still post 75, but no longer at the bottom of the page.
Here is the original article.
https://www.vwvortex.com/threads/how-to-repair-or-re-key-door-locks.3496179/#post-42591508
Choose Exterior
DIY Guides
http://cabby-info.com/Files/RepairingDoorLocks.pdf
On the drive
Myvalver 89 GTi Grey mk2 16v
Just saw my ytpo…
http://cabby-info.com/Files/RepairingDoorLocks.pdflinders. linders shouldn't be there….. OPPSY my Bad.
