Dash lights help needed
(In Topic #235019)
So
I’ve removed my dash pod and fitted new bulbs and also the LCD clock which was also gone.
I’ve replaced and tested before putting the everything back together and , I now have an LCD clock, but no dash lights at all when the lights are switched on, also missing is the high beam tell tail.
What could be wrong?
Also, In the H/light switch there is also a bulb which looks to me like it’s long time blown, could this be changed as I am struggling to get it out of the switch.
It’s a ‘91 Cabrio
So now all I’m missing is speedo illumination and H/light Switch illumination
To replace it just use a hot knife to melt the cover in place.
Yours is a 91, the cluster on all my 90's was Motometer, not VDO. You have Plumped the connector (main) with a piece of electrical tape under the mylar pin side of the plastic?
