Dash lights helllp
(In Topic #218164)
Hi I have recently changed the module which has the headlight switch and dash dimmer on because that's what I believed to be the problem for the lights not working
After doing so unfortunately it hasn't fixed the problem could anyone help me
Cabriolet?
So you changed the Dimmer out only to find that it didn't resolve the issue….
The issues that I have seen over the years (dependant on year of Cabriolet).
The 90's had a fuse earlier ones tended to be like a early British Leyland where the Wires protected the fuse.
I would say Take the cluster out (clocks). Beef up the connections and add a direct ground to pin 2.
Make sure that you have B+ on the Gray Blue wire to pin 2 Brown, if that is there, then your bulbs are bad. It isn't unusual for them all to go out at the same time.
Repairing flaky Grounds on the Cluster.
Improving your Cluster Connections and ground. | Volkswagen Owners Club Forum.
Order or acquire 3 Bulbs just change them while you are checking for 12V from pin 14 (black) to pin 2 ground (brown), and 12v from the Gray/blue wire (pin1 usually)…..to pin 2(brown) or earth.
If all your other gauge lights work, it's the bulbs.
Now if the fuse is blown, then you have a short to ground on the Gray/blue wire, and I have seen that toast every other wire it touches……
Dash lights helllp
Sorry yes it's a 1985 cabriolet I will pull the cluster out and have a look
