Cutting out issue hellllp
(In Topic #218332)
It occasionally judders when trying to over take on a dual carriageway which is a nightmare in it's self but the main problem is as I approach a round about or slow down to idle a lot of the times it just cuts out, turn it off and on again and it pretty much goes straight away
I have changed the fuel lines both fuel pumps all filters and plugs, cleaned the tank put new fuel in changed the warm up regulator(for a second hand one) but I knew it was working
Any help would be great
How is the timing?
Idle screw coming lose on back of throttle body?
Some thoughts which spring to mind…..
I have changed the cam belt however I had a friend of mine come help me with the timing because I was a little bit out on the distribution pulley and it runs ok for a lot of the time so I would say that is ok could check it again though
And if the idle screw has come lose could that cause it too cut out, I read somewhere there is a little o ring on there prown to breaking is the correct
