Crankshaft oil seal 1.8
(In Topic #223874)
i have found a guide here on the forum for changing the intermediate shaft oil seal, timing belt end of engine, it looks pretty easy, is the crankshaft oil seal a similar job?
ive got as far as changing the timing belt , and found a lot of oil around the bottom cover, not sure exactly where it’s coming from so I’ve ordered both seals….
You'll need to remove the lower timing cover, aux belt pulley and the crank pulley (fun job!). You will also need a gasket that goes between the plate and the block for reassembly.
So yes, it is do able, but not as easy as the intermediate shaft seal.
I've got the cooling system, water pump, radiator, timing covers and pulleys all removed, may as well drop the sump off as well, sump gasket is leaking anyway…
Happy dayz! (not) LoL
Thanks again
If the Tranny is mounted start each one at the rear and the front by hand and a wobble socket will be your friend.
Engine and tranny are in situ, it's an auto if that makes a difference?
It's gotta be done so, deep breath !!!
