Changed main fuel pump now will not start
(In Topic #230408)
Changed main pump underneath the car.
Car does not want to start. Assume it's due to fuel lines being empty.
How much priming will it need?
Sent from my AC2003 using Tapatalk
Greenmk1 said
Are you getting fuel at the metering head in the engine bay?
assume not - car was running prior to changing pump.
if still issues check non return valve in right way… on pump.. and that power cables not in reverse, should be different sizes to prevent mix up. but still possible.
On the drive
Myvalver 89 GTi Grey mk2 16v
Regional Host NE
nicci21paul said
no the problem you are having mate been there
How did you solve it?
The car is a 1.8 cabriolet 1987. I have never heard the lifter or main pump prime only heard the main pump when car is running.
The lifter pump was changed a couple of weeks ago. Had no issues with that but trust would not have affected the accumulator.
Perhaps not giving it long enough
Regional Host NE
Regional Host NE
nicci21paul said
if you want to ring me 07739608140
Many thanks Paul for your advice. Will try what you suggested when it warms up. Thanks
Regional Host NE
