Centre instrument console
(In Topic #217887)
Mk1 GTi engine code EG
Am fitting a centre console in my Mk1.
It came in a box of bits with the car.
The instruments all seem ok.
Am unsure what it fastens to at the gear-lever end.
There is a hole in the moulding which is central
but if I fasten it down using a slightly longer bolt into
the rearmost gear lever securing plate bolt hole the gear lever
is quite close to the back of the hole where the gaiter fits.
If I place it with the gear lever central when in neutral it appears
to be too far away from the under tray at the front
Many assistance very much appreciated
Thank you
On the non-a/c I think there are brackets.
ps I usually leave the two top ones off, and secure the console at the rear tranny.
Might you have a look at the etka for the parts breakdown as it is a good place to see where all the stuff bolt to.
http://www.oemepc.com/
Might want to bookmark that site for future reference.
Many thanks for that
Most helpful.
Had a look at mine - no raised tab behind the gear lever
but the car had been 'butchered' by a previous owner to be used
as a track car.
If I secure the console with the gear lever in the neutral
position as close to the centre of the gaiter hole as I can
do you think that would be about right?
Again many thanks for your assistance
Very much appreciated.
