Central locking positioning
(In Topic #224137)
Whip
/wip/
Noun - Car
/wip/
Noun - Car
If so then I have done this. Try to get them as close to the top of the door as possible. I think I ended up attaching mine to the inside of the inside of the door (if that makes sense) in as direct a line as possible from the lock bit that they actuate.
There is a bit of fiddling and bending required to get the lines correct. Quite a bit of adjusting is also required. Make sure you have the passenger door open in case you get locked out!
Ian
Yup.borednow said
Is this a new set up?
So inside of the inner door skin? Like where mine is but higher?borednow said
I think I ended up attaching mine to the inside of the inside of the door (if that makes sense)…
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Just don't ask how I know about making sure the other door is open………… Ian
borednow said
Just don't ask how I know about making sure the other door is open.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
