Cambelt & timing marks
(In Topic #222503)
Move it one tooth?
Hi folks,
fitted my new cam belt, and manually turned the engine over a few times after tensioning it - as standard.
Timing mark now looks to be maybe 1/2 to one tooth of depending on where you think the measure should be taken from.
This is how it currently looks:
Bottom pulley is at the correct position:
You can see from the first photo that if I moved it round then it would be pretty much in line with the top of the head casting - not the cam cover. Hyanes manual indicates it should it should be in line with the cam cover.
I guess that when the belt is tensioned it will rotate the cam sprocket counter-clockwise which is probably why it's moved.
What do we think? Move it forward one tooth, or leave it where it is…?
Move it, that is if the 0 tdc mark is correct and the dizzy rotor is still centered in the hash stamp, then back it off and re-adjust it to be even with the plane of the head.
My opinion for what it's worth has now changed, I would move it as Brian said.
Last edit: by cedar
I'd say you're a tooth out there too, best to change it. I had the same when I tensioned the belt, spent a bit of time making sure it was right.
Thanks chaps,
I'll have a mess with it and get it right. Easier to do it before I put the engine in.
J
J
