Cabby waistline
(In Topic #228593)
Hey guys,
I've a 85 gti clipper cabby in the middle of a cosmetic overhaul- am I right in saying the correct waistline trim is the thicker one? (that's what's been on it)
And, is there a physical difference to the channel in the panels in which it sits compared to a tin top?
I just offered up a skinny one too it and it looked a bit lost, but I'm not sure if that's just different to what I'm used to or if it was never designed to be on there.
85 did not come in a Clipper variety.
85 did not have the thicker waist line trim that the
Clipper came with.
A clipper cabby (true clipper) prior to 1990 had a Thicker Chrome centered black outside waist line trim that was held into place by white plastic with washers clips.
The 1990-93 Clippers has a "solid black waist line trim that was held in place with the same pre-90 clips.
The OEM Clipper versions waist line trims fit in to the same channel that all GOLFS/Rabbits of the mk1 Variety had…
Yes I am aware that yall over there had a bunch of different versions and such, so I am basicallly stating that the obvious term for the Clipper variety that we saw over here in late 87-93.
Clipper came with.
Thanks!
Well I already look like the n00b I am- I have always had in my head a 'D' plate was 85. but it's pretty clearly on the v5c from Jan 87. What a very obvious thing to have wrong
I'd always taken it at face value the clipper kit was factory fitted, but now the more I look, the more I realise (spurred on by your reply) that's probably not the case- my car is single headlight grill too.
Clipper came with.
Hi Andy
i have a full set of the correct trims for your car if you’re interested
Simon
Simon
Mk1cabsportline said
Hi Andy
Simon
ohh- quite possibly- I'll drop you a PM in a bit.
