CABBY FUEL PUMP making noise
(In Topic #214942)
External fuel pump under tank making noise
Golf 1993 clipper
Audi A3 S line Quattro
Golf 1993 clipper
only wires going to the tank are for the gauge sender unit
put your hand on the pump and you should feel it vibrating
some are loud but if its got louder then somethings wrong
new pumps are around £80 to £120 depends where you go
Golf 1993 clipper
Golf 1993 clipper
I guess disconnect the easy one that will tell you which one making the din
If I'm lucky mite just be lift pump £30 job lol
Golf 1993 clipper
good luck
Golf 1993 clipper
I would replace the in-tank pump first, it's cheaper.
It could also be the sump/filter on the side, but usually the in-tank.
Replace the in-tank first, then add about 1pt of Marvel Mystery Oil to the gas and see if the noise abates, as it should the MMO will reduce the lacquered fuel residue on the primary pump.
Golf 1993 clipper
Unplug the lift pump power supply and see if there is any change in the noise or if you can hear the lift pump working.
In 280,000 miles and 22 years I've been through 5 lift pumps and 1 main pump.
Golf 1993 clipper
Golf 1993 clipper
No, if the main pump is whining, it is whining because it is working harder than was designed for.scotty b said
Ok so I've just checked I can here my lift pump when I turn key when I start the car in getting the noise coming from the main pump whiningthen when o disconnect lead on lift pump the same noise is still there I'm guessing main pump change
Just because you hear the pump, doesn't mean it is pushing fuel to the main via the sump/filter/swirl pot that is affixed to the right side of the tank. As a matter of fact, the fuel system primes at key on, that it is runs for 4 seconds, and the throbbing you hear at key on is to tell you that the fuel system is primed, and usually it will eliminate a Vapor Lock condition and ease starting.
Disconnecting it and still hearing the noise doesn't mean that your main is bad, it only verifies that you have an obstruction to the main. I mean the main could still be bad, but whereas the main pump is between 120 bucks and 240, the lift pump is only 50-80.
I have 189K on one of my Cabriolets, and I have been through 3 lift pumps and no primary ones.
I had about 190 on another one of my cabbies and the Main pump decided to quit 2 weeks before Christmas, and I did the single pump conversion…for 80 totally.
I would strongly urge you to replace the in-tank pump and filter screen first, give it a go.
Per the Bentley the in-tank and primary pump on a 90-ish Digi car are both the same working pressures and flow rate.
It is just my experience in them that tells me the intank pump is either Dead, or the interconnect hose is holed or broken.
When replacing the in-tank pump replace the interconnect hose/dampner with a piece of fuel rated
hose 5/16" IIRC.
If your main pump was dead and you disconnected the lift pump you would have no pumps working and the car will stop.
hopefully it may fix my issue
Golf 1993 clipper
