Brake pedal to brake linkage rod length - solved!
(In Topic #225128)
How can I set this....
Need to re-connect my brake pedal to the rod that goes through the bulkhead to the main linkage. According to Mr Haynes there is a set measure for this (well 2 in fact, but I'll come back to that).
Given that my linkage is all bolted up in the engine bay, I can't remove the rod in question as the rubber grommet/bellows thing must go in from the engine side. Any suggestions as to how I can set the measurement - is there some other way of making sure this is set up correctly?
On the measurement front - it changed at a certain chassis number. Now, possibly a really dumb question, but how can I find out my chassis number? I looked at the VIN plate, but the only number on there starts VWWV or similar whereas the chassis numbers in the Haynes are fully numeric - and long - and bear no resemblance to anything I can see.
Cheers.
Jason
Last edit: by paceman
If you haven't altered the clutch adjustment (or its not an auto!) then you can "work backwards" and set the brake pedal height relative to the clutch pedal, I think its 20mm but its in the Haynes manual too.
I've actually just stumbled across this post from a few years back which is basically the same question.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Frunning-gear_2%2Fbrake-linkage-lenth
you answered that one as well!
Thanks!
J
I'll see if I get the rod out from the front, measure it, mark it, and refit.
Thanks again.
