Brake pedal return spring?????
(In Topic #223841)
Can anyone show me a decent photo of the return spring in position where the pedal attaches to the steering column????? I THOUGHT! the spring was to the left side of the pedal - NOT the right side as shown in this diagram?????? Puzzled.
No Ian, I can't ignore the spring - is that a proper bodge?!? Or does it stop you being over-zealous with the loud pedal?
It's cos the bile carbs return spring isn't man enough to pull the accelerator pedal back up all the way.
Without it the ratio of the carb twist to the throw on the pedal was all wrong. Amazing what a couple of mm helps with!
Ian
Ian
borednow said
Dunno if that helps at all?
Ignore the spring going to the accelerator pedal!
Ian
Thanks for that Ian!
Ian
Kind of like the Wizard of OZ saying to Dorothy, Ignore the man behind the Curtain…….paceman said
Briano1234 said
Ian
It's when you have to modify the modifications that you had to modify in the beginning that you begin to wonder if you should have just left it alone in the first place
