Brake pedal return spring?????
(In Topic #223841)
Without it the ratio of the carb twist to the throw on the pedal was all wrong. Amazing what a couple of mm helps with!
Ian
borednow said
Dunno if that helps at all?
Ignore the spring going to the accelerator pedal!
Ian
Thanks for that Ian!
Ian
Kind of like the Wizard of OZ saying to Dorothy, Ignore the man behind the Curtain…….paceman said
No Ian, I can't ignore the spring
Briano1234 said
Ian
It's when you have to modify the modifications that you had to modify in the beginning that you begin to wonder if you should have just left it alone in the first place
