Brake Pedal Assistance
(In Topic #210500)
You need to remove the clevis pin from the pedal, and work it out. It is a pain but it can be done.
There is the main rod at the top and a return spring that you have to contend with.
Pin at the Top that goes through to the clutch side.
Pin that holds the Clevis to the Pedal,
Return spring.
see: LHD but is the same.
http://www.oemepc.com/vw/part_single/catalog/vw/markt/USA/modell/CONV/year/1986/drive_standart/44/hg_ug/721/subcategory/126000/part_id/3691702/lang/e
Cheers mate. I have all the stuff off the pedal, I just can't get the pin out (no 12).
Looks like it should just drift out with a few blows. Probably just corroded in place. I shall hit it harder then!
Ta, Ian
abfmk1 said
Yeah that's correct , remove clip and drift it out, removed mine yesterday, are you trying to do it in situ? might make it a bit harder. I removed my column and on the bench the pin popped out easily.
Yup, in situ mate. I shall just belt it a bit harder. Just needed confirmation that there wasn't something I was missing and was about to bend or break.
Thanks chaps
Ian
