Brake compensator valve
(In Topic #237515)
either if any others fit or if there are rebuild kits?
Mine is seized solid and the only one I can find is one on eBay in worse condition than mine.
Thought I had found some on auto doc but then realised they were out of stock. 🙄
would really appreciate any advice.
the Cabriolets have them at the MC and not load sensing as some of the Golfs and Cabbies had.
Briano1234 said
They are pricey at either werks34 or vwheritage, I can't remember where I found it for some one, but I would say
Thanks. I haven't been able to find one anywhere. The one I'm after is the one that looks like the m/c with a spring by rear axle. Is the alternative to fit the inline ones up front and redo some brake lines?
skoda
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=skoda+rear+brake+force+regulator&_sacat=0&LH_TitleDesc=0&_odkw=vw+cabrio+rear+brake+force+regulator&_osacat=0
found this as well on a search for vw mk1 rear brake force regulator.
Briano1234 said
There is one for a 90 cabrio () forsale on ebay
skoda
Thank you!!
Have seen those as well but they are a different layout. Guess I will need to make a bracket and maybe change some brake lines to get the square one to fit. Maybe I'll buy one and get under the car this weekend and see what's what.
Appreciate your help!
Regional Host NE
Carl Jones said
If you want a rebuild use pastparts which did mine recently.
Thanks. Can I ask what the cost and lead time was roughly?
