Boot Lock
(In Topic #233698)
Stuck in
Boot Lock
I assume this is on a cabrio is it?
The Spray the Button part of the assembly between the seal and the button, work the button.
Second way, remove the parcel shelf, You don't need to lower the seat back just pop it up off the clips then work it out. You can then get to the cardboard cover that is over the locking mech, Could be the spring is out of position or the clip on the rod.
Once you get the cover off then push the rod down.
Boot should open.
My panic is over for now though, it took quite a bit of WD40 and patients.
I think it happened due to me not unlocking the boot correctly. The barrel on mine appears vertical when its locked. As I turned the key to the horizontal position to unlock, I pushed the barrel in at the same time. It must have managed to trap something.
I have removed the panel that Briano1234 showed and there is some play in the lock.
