Battery cables what ones do i need ?
(In Topic #215345)
I opted for 2 off the shelf cables from a parts store, I measured the distance from the battery to the frame connector and the Frame to the engine/tranny.
I bought one cable from the battery to the frame with enough pigtails to splice the add-on wires and do away with all but one ring connector.
I tied this to the frame horn, I took a battery to battery Jumper the same length as the one from the Frame to the engine/tranny mount and added that.
ylon pa
Along with this is that at the Frame horn, I cleaned the Study.
Prior to install I flattened the stud ends with a hammer and slightly scuffed them flat. I mounted them as a flat washer against the frame, Cable end, flat washer then cable end to the engine'/tranny followed by flat washer and lock washer and nut.
After tightening them I sprayed the connection with battery corrosion protective paint….
One one of my Beasties I replaced the main Power with a similar cable (red of course, with Pig tail take offs to eliminate the few Ring connectors present.
Now here are the Caveats. You have to have a good pair of Crimper Pliers, the ones that dimple the middle and have long handles to ensure a proper crimp on the butt connectors. I also sprayed the Butts with Clear Krylon paint to water proof….
Cleaning frame horn
removing onepiece cable
battery paint
