At the side of the road
(In Topic #223171)
to rule out starter next time it happens run a live wire direct from battery to the red/black wire spade on the starter motor. while here make sure the spade is clean and tight. if the starter cranks when jumped direct, check ignition switch wiring and the alarm gubbins. to rule out ignition switch unplug it and loop a wire from red to red/black see if it cranks over.
its worth having all the starter, battery and alternator cables off for a good clean up. the gearbox earth goes to the bracket on top of the gearbox, this can get corrosion buildup underneath, to rule that out put a jump lead from battery negative to one of the bolts holding the starter on, if it cranks up lovely then sort this out.
later mk2 and mk3 moved the box earth to a stud on the end of one of the 2 upper bolts holding the gearbox on, fit one of those and either redo the earth entirely or run a cable from exisi8nt earth point to the new point. I like to use a complete set of mk3 golf cables nicked off a 1.8-2.0. grab a 2nd earth from another mk3 and chop it down so you have a length of wire with a ring terminal either end, bolt one side to the chassis earth point and the other to the ring terminal in the middle of the 1st earth
the 2e2 needs coolant flow for the autochoke and waxstat to work properly so if it was leaking before its possible it wasnt getting good flow and someone has fiddled with the settings to compensate for this
if its a weber just may need idle and co tweaked
Ps I'm still having the issue of not wanting to tick over
