Alternator wiring route.
(In Topic #227088)
Thanks Steve.
battery down and across to coolant pipe then behind the radiator shroud to the terminal.
Vic said
Whilst you're checking wiring check the radiator fan and that it has no chance of going adrift and possibly being caught in the fan. If the metal coolant pipe has been changed prior to your ownership check it's not cable tied as the welded nuts do drop off!!
I have one radiator fan that the connection on the back of the fan is so iffy, that I wire tied the connector to the plug…
