Air intake hose where to find one?
Hi all. Need a new air intake hose for my cab sportline as the foam coating has all split and perished. Anyone point me to the correct one struggling to find one? . Thanks for the help 20181016_201159.jpg 20181016_201140.jpg
Last edit: by ajc1984
No one?
If you can't find one from any UK suppliers I recommend trying here https://www.mecatechnic.com/en-GB/ they may have what your looking for?
Thanks had seen that was just after something more OEM
No luck there!! Anyone know what the diamiter would be maybe I can get something close
Isn't that the Air Snorkel Hose, goes to the air box from behind and under the front Valance or slam panel as y'all call it?
You can use Pre-Heater hose it comes in a variety of Lengths is either usually Black or Silver can be bent and Twisted around things.
It is like DRYer discharge hose.  I have seen folks do away with that and modify the Air Box to use PVC pipe from the hardware store to improve air flow.
Om my 90''s I used pre-heat hose and ran it from behind the Grille to the Airbox but Digi is a little easier to mod that CIS.
Yeah thats the right hose... so sounds like aftermarket is the only option then. Im not concerned about the work to fit as its just getting some flexi hose and clamping it on it was more I wanted OEM but if it doesnt exist anymore fine. Why was it wrapped in foam originally? Do you know the internal diamiter of the hose at all so I could find a suitable replacement?
If you still have the "hard pipe" parts you'll get a diameter off that
Cool will drop it out this weekend and come up with a plan
My cabriolet does not have foam around that pipe, it's just plastic, that's how the 88 Car came out of the factory.
