Adjusting Cabriolet Windows
(In Topic #219114)
There's slight gaps at the front too.
Thanks in advance
Last edit: by karmannndunc
Prior to any and all adjustments are the seals themselves. The seals on the frame are in Trays, you can pop them in and out easily for the rear and middle, but you have to start in the middle and work towards the ends to keep the end caps in place.
You need to look at the screws, they are in a slot. The trays should be at the most outside position on the screws. So that the seals will contact the glass, and makes the adjustments on the glass easier.
You need to address any sag to the door.
If the door isn't hanging correctly, then that is why your adjustments are out to begin with.
Saggy Door Fix | Volkswagen Owners Club Forum
Only when the door isn't sagging can you proceed with adjustments.
Then and only then you need to roll the window down and back up.
The window needs to seal not only at the top, but the rear edge of the seal.
The rear edge is adjusted by moving the 2 bolts at the bottom of the door in or out towards the inside of the cabin in relation to movement.
Moving the bolt to the outside of the door makes the glass tighter to the seal while moving it inside makes the glass move away from the seal.
The Glass should engage and roll gently in to the seal at the top, so that if you shut the door with the top up it doesn't push away from the door on the rear edge.
There isn't but about 1/16 to 1/8 of a roll in of the top edge of the glass to the seal.
The window stop helps to get the window to the right height, that is the center bolt with the large washer.
The engagement of the window seal to the glass at the ends is usually controlled by the bolts that hold the glass to the regulator, you can take either end up or down.
Now here is a list of How-to's with photos of every thing mentioned above, yes you have to browse them all, but every leak and adjustment is mentioned.
Top frame Seals:
https://volkswagenowne…Seals?p=605050#post605050
How I install convertible tops shows you the seal trays, and where the adjustments are, the front "a" pillar is glued at the front, but the rear 4 screws are adjustable and should be moved to the outside. If you take the Trays out, clean the foam, and apply new. Even is you have to move them take them off and clean and apply new foam. Do not honk down and super tighten the screws you will only strip the nylon keepers.
https://volkswagenowne…vertible-Top-Installation
"A" pillar gap repair.
https://volkswagenowne…uot-pillar-repair-the-Gap.
Wind Noise at the leading edge.
https://volkswagenowne…-top.?p=655074#post655074
"A" pillar door seal repair, stop the drip.
https://volkswagenowne…t-A-quot-Pillar-Door-Seal
Leaky Car Syndrome fixes:
Another Leaky Knee Fix.
http://www.toplessrabb…viewtopic.php?f=41&t=2737
Swimming Pool in Front Seats.
http://www.toplessrabb…viewtopic.php?f=41&t=2853
Where is my top leaking.
http://www.toplessrabb…viewtopic.php?f=41&t=2655
Where is my trunk leaking.
https://volkswagenowne…Where-is-my-Trunk-Leaking
Why are my feet Getting wet, all I did was change the antenna.(Drip Stop Loop)
https://volkswagenowne…-just-changed-the-antenna…..
How to un-bolt pivot windows hardware.
http://forums.vwvortex…p&p=87874731#post87874731
All my how-to's are linked in the archive section
below in the how-to, brianos 90ish cabby …while the engines are for Digifant, most of the other stuff applies to all cabbies.
Didn't think it would be an easy answer did you?
Common problem for them to snap, it's possible to change them with the roof in place.
Check and feel if there is any tension in the sides of the roof, if you 1/2 open the roof you can see where the cables attach.
Kept my little ones from the sun. It also kept the police from seeing my baby daughter when she took her favorite position, on top of the parcel shelf.
Last edit: by LeilaniGibbs
