Additional front fog lights
(In Topic #219588)
Ideally ones that come on with the second click of the stock fog light switch
Thanks all
I know my 1988 cabriolet has the wiring already there to plug in fog lights, there's a yellow cable and plug underneath the coolant expansion tank…
Not sure how they work etc but at a guess it’s probably wired up like the rear fog light as you need the headlights on for the fog lights to come on so I guess you would need the main beam lights on to get the front fog lights to work as that’s what fog lights are for… to use when it’s foggy unlike loads of muppets I see driving around with side lights and fog lights on usually in the rain blinding on coming drivers….
So if i have the plug already its just wiring? Do they work from the second click on the existing switch only or would I need the full beam on as it is now?
I usually see people with fog lights on when it isnt even foggy. No one seems to know the highway code for fog light use!!
Do you have a link or know where I can buy the extension to run down to the front bumper?
fog lights on a campaign
driving lights on twin light grill,
sporttrucker said
campaigns had fog lights from factory, they have different lenses than driving lights that come on twin light grills.
also the GX and Driver had Foglights fitted in the Grill.
Regards Volkswarren
when fitting front fogs you also need to change the wiring slightly, otherwise they will get lower voltage than they should.
for CE1 fusebox this is dead easy, first drop the fusebox off its hangers and look for the grey/yellow wire plugged into the back, pull that out. dig a bit more and find the other grey/yellow which wasnt plugged into anything, then join them together. put the fusebox back in the hanger, fit a 53 relay in slot 7 and a 10a fuse in slot 6. done
