Accumulator - yay or nay!?
(In Topic #236826)
Fueling help
Running 2.0l 16v 9a from a Corrado with CIS-E engine management.
My current setup is:
Polo GTI in tank lift pump > fuel filter > fuel pump (BOSCH 044) > fuel pressure regulator (fpr) > metering head
I'm going to add a swirl pot (part nr. 533201511A) between the fuel filter and fuel pump to alleviate any fuel starvation issues, question is, do I also need to fit an accumulator between the fuel pump and fpr?
Last edit: by Spidermonkey84
'84 MK1 Golf - View topic: Humble Beginnings........... - VW Golf Mk1 Owners Club '99 MK4 Golf
And if not, do you experience any fuel starvation issues?
abfmk1 said
If you mean the original accumulator fitted to k-jet cars then i believe it is only a requirement for k-jet…
Ah ok, seeing as I'm running CIS-E then I should be ok then.
Mine started out as 1100cc so I never had an accumulator to start with
Carl Jones said
Where you have mentioned fuel filter this should be the swirl pot (as per part number you mentioned) fuel filter after fuel pump before metering head.
Right ok, I can swop those around then, cheers
