ABF OBD possible crank sensor.
(In Topic #224332)
I have a mk1 GTI running an ABF from a '97 Golf GTI. It is running standard MK3 management and injection. Car intermittently cuts out/runs badly. Changed plugs, leads, drained tank changed filter. I have the diagnostic port fitted, I have a cheap ELM 327 bluetooth OBD adapter the only app I have on my phone is Torque this does not recognise the protocol apparently. Can anyone recommend an app that works?
The reason for the above is that I suspect the crank shaft sensor is at fault. I have noticed that when the car is difficult to start the tacho does not move when cranking. I believe the ABF takes its engine speed from the crank shaft sensor if someone could confirm that would be great.
Also which crank sensor would anyone recommend?
Thanks in advance.
Steve1973 do you happen to know what the correct trace might look like? peak to peak etc.
Can anyone recommend a brand of crank sensor. Or at least the ones to avoid!!!
Many Thanks
Its a 3 wire hall effect type. I suspect I would see a pattern of 4 square waves. But as the fault is intermittent its a bit of a moot point.
