ABF Fuel Pump Set Up
(In Topic #232877)
Afternoon.
So I've got the ABF sat in the bay, K plate Mk1 Golf Conv Clipper.
Id say most of it is wired up, apart from bolting the Knock and Crank Sensors in.
I really want to get this running now.
Question I have for you brainy bunch is can I still run the existing 1.8 Sender that's in the back seat, or does that have to be changed as that's 2 pin as apposed to GTi being 4 pin?
Should I just get the Fuel Loom from a GTi and use that and obviously run a F/P & Filter.
Do I still use the existing metal fuel lines that run underneath to the Engine bay? 6mm.
What do I do?
Any suggestions?
MJ
What do I do?
Any suggestions?
MJ
MJ
@DjMj73
@DjMj73
Regional Host NE
Re: ABF Fuel Pump Set Up
So is the sender in the tank a carb or injection previouslymjvr6 said
Afternoon.
What do I do?
Any suggestions?
MJ
Sent from my SM-G955F using Tapatalk
1.8 Carb bud.
Sorry should have written it a tad clearer.
MJ
MJ
MJ
@DjMj73
@DjMj73
Regional Host NE
Re: Re: ABF Fuel Pump Set Up
Afternoon.
What do I do?
Any suggestions?
MJ
Regional Host NE
Re:
Doing a similar task carburettor to GTI I have used the sender with in tank pump changed the pipes to 8mm from the 6mm fitted to the clippermjvr6 said
1.8 Carb bud.
MJ
1.8 Carb bud.
MJ
Are you not bolting on a F/P and Filter as well?
MJ
MJ
@DjMj73
@DjMj73
Regional Host NE
Re:
Using GTI swirl pot fuel pump accumulator then fuel filter into metering headmjvr6 said
1.8 Carb bud.
MJ
MJ
You drop the tank down dude or you got to it easy underneath?
Mj
Mj
MJ
@DjMj73
@DjMj73
Regional Host NE
Re:
Probably depends on which way you decide to to change the pipe work you will need to drop the tank down on the driver's sidemjvr6 said
Mj
Mj
Yes gonna to see what I can do. I dont need the Swirl Pot, well at least I dont think so.
MJ
@DjMj73
@DjMj73
