ABF'd MK1 tin top cutting out
(In Topic #242574)
Hi all
Not been that active on here for a while as the car has been off the road for a couple of years. However, now its hit 40 I though I'd better sort it out.
Got her insured last Friday and had a little run, so thought I'd take it to work to day. Got about 4 miles...
Just cut out.
At first I though fuel pump as I couldn't hear it. It's usually pretty noisy, but there was just too much background noise.
I also though it could be the 2 yr old fuel in the tank, but when running it was sweet so unlikely to be that.
Then after a 30 min cool down, it started back up. So not fuel pump, or fuel me thinks.
I tried to get home, but I got less than half a mile in traffic so thought I'd sit tight and call AA as I was in a reasonably safe none obstructive place.
AA man thinks ABF ignition module.
I posted up on the Facebook page, and to be expected got a fairly mixed response.
Including some of the following:-
Hall effect sensor
Crank / cam sensor (seems to be a popular choice)
Fuel pump relay
Coil
Coolant temp sensor
ECU relay
WUR (didn't think the ABF had one)
Distributor
Injector seals
As it is an intermittent fault I only know if it is in fault mode if it stops.
I do have VCDS - will it help me? I'll see if it's logged any codes later, but I'm a very infrequent user (read complete novice)
Clearly I don't just want to throw a load of money at it and hope.
So where to start?Any suggestions with links to diagnose?
I quite enjoyed the 4 miles I had, but need to be confident I have found the fault before taking it out again.
Many thanks
I have also discovered I have a spare crank position sensor in my kit, so going to try that first.
Next is to take it for a run, if i'm brave enough.
Regional Host NE
